Buy Used Saws CCC Ebay Store
Remington
Discussion in 'Brand Specific Section' started by 67L36Driver, Oct 14, 2016.
  1. fossil
    fossil Pinnacle OPE Member
    688
    2,758
    255
    Ontario, Canada
    Thanks Carl. It is there. 0.020". Appreciate the reply.
    67L36Driver and msellers like this.
  2. 67L36Driver
    67L36Driver Here For The Long Haul!
    5,946
    20,435
    448
    The SL-5R uses 9/16”.
    [​IMG]
    msellers and fossil like this.
  3. Mastermind
    Mastermind Leader Of The Clique Staff Member
    22,646
    127,882
    931
    I bought a Super 990 and the chain came with it.
  4. fossil
    688
    2,758
    255
    Ontario, Canada
    Found the bolt size for the rear handle lower holes and feeling pretty stupid I asked.
  5. 67L36Driver
    5,946
    20,435
    448
    Most common size used on Remington and Homelite back then is #12-24.
    I have a Helicoil repair kit for that size. Left over from when I ran Holly carb on my vet. Leaky float bowel screws.
    fossil and msellers like this.
  6. fossil
    688
    2,758
    255
    Ontario, Canada
    Some of the screws didn't give sizes but the one I was looking for did on the IPL . The 990 seems to be mostly 1/4-20 with a few number 12's and at least one 1/4-28 nut. The crank nut is a fine 7/16 thread.
    Almost back together now. I picked up a couple of 1/4-20 square nuts tonight for the rear handle upper bolts and then add the front handlebar and clutch. I hope to hell it runs.
    I must have 20 hours in cleaning as the saw cake had dried out and was tough to get off. The tanks were clean. Bit of a pain to assemble it all. I did manage to cross the FW side seal with an exact replacement SKF seal. Kind of an oddball seal.
    rocketnorton and 67L36Driver like this.
  7. fossil
    688
    2,758
    255
    Ontario, Canada
    Super 990 finally together and ready for a test start. I think it runs pretty well so far. I need to get it in a bit of wood.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
