Larry B
- 10:28 AM
- Sep 2, 2017
- SW ohio
Transaxle is all back together with the new input shaft pulley, key, and snap ring. The pulley does have a bit of wobble to it, although nothing like the old one which had the key and keyway worn out. Is this normal? Best as I can tell, the shaft is tight in the housing, all the wobble seems to be from the pulley on the shaft.
The ones with only a snap ring with no set screws tend to wobble and enlarge the hole. I shim them with a piece of steel soup can.
