Redlinefever husky 394 build
Moparmyway
Its just a saw
9:44 AM
In a meeting
I’m not an expert, but I’ve noticed one clear indication
See the threaded holes on the front face, down near the bottom ?
I’ve never seen a 394 with them. They’re for mounting the wrap protection plate
394 without the threaded bosses
395 with plate
Jimmy in NC
9:44 AM
North Carolina
Sounds like you have a 395 piston, they have a shorter skirt and would cause the intake timing to fall close to there.
How do the Meteor pistons fall out? More 395 than 394?
Sent from my SM-G920V using Tapatalk
RIDE-RED 350r
9:44 AM
Blossvale NY
Kevin I think the later model 394 did have those threaded inserts
This is correct. My 394 built in 1993 does not have the plate mounting boss and threaded holes. The 394 made in 1998 that belongs to my employer does.
Safe to say if there aint no holes, then for sure it’s a 394............ ?
Also correct
Moparmyway
Its just a saw
9:44 AM
In a meeting
Remind me how to tell what the year is ...... I’ve got a few 394’s here ......... all without the holes. Mayhaps one is a 97 ..........
RIDE-RED 350r
9:44 AM
Blossvale NY
FWIW, ifin' you get a wrap handle kit and want to install the plate, it can be done on the older 394. Just drill and tap. The holes should not go into the oil tank, but will be close. Here is my pre-hole 394 with the plate installed.
9:44 AM
It's very interesting the various idiosyncrasies they've done over the years to the saws. Looking at the IPL's helps.
