Never heard of different rod sizes on these. Are you sure your piston is for a 670?Been sitting on a new jug and piston,thought now was a good time to use them.View attachment 16901 View attachment 16902 But, the rod end is the wrong size for the new piston. So,will make the best with what I have.
Looks like you are correct. The piston's number is 503 50 27 02 and is 52mm. Funny,has 670 written on it so I thought it went with the jug.Never heard of different rod sizes on these. Are you sure your piston is for a 670?
May be an echo 670? No idea. You need a 50mm windowed piston for a jred 670 or a 268xp. Meteor or oem would be my choiceLooks like you are correct. The piston's number is 503 50 27 02 and is 52mm. Funny,has 670 written on it so I thought it went with the jug.
503-5027-02=281=52mm. I've got a pretty nice 670 Champ. Don't understand why you had to grind side of cyl. I have a bunch of theis series 266-272-61-66 never saw clearance issues. Have several extra OEM & Meteor pistons. PM if interested.Looks like you are correct. The piston's number is 503 50 27 02 and is 52mm. Funny,has 670 written on it so I thought it went with the jug.
I forget how much I machined from mine. I had no clearance issues either. Either way it should run real good. I am surprised that more people are not interested in this build. These are awesome saws and there is a ton of them around.
