redlight066
- 9:12 AM
- Apr 1, 2018
- Taylors SC
Anyone here spun or sharpened a loop of C83? First loop I Spun ruined the anvil on my spinner. I thought OK it's well used, I'll order a fresh one. OEM anvil shows up and I can hear the grinding noise again so I stop before I ruin another. I can only assume that because the rivets are a touch smaller than it's counterparts, Husky made it out of a harder alloy. Reached out to my Husqvarna rep and he was useless. I've been using some left over EXL straps and havent had an issue. This morning I decided to spin a 28" loop and convert it to square. First side goes fine. Then I start on the right side cutters. I get a few done and I go through a series of over hardened cutters. It felt like running the file over glass, if that makes sense. Ruined two Pferd and one save edge double bevel file. Just wiped the teeth off the files trying to finish the loop so I put it to the side and I'll probably just put it on the grinder and put it back to round ground.
I'm more interested in the straps and anvil feed back. I should have put this under "just chains" but this thread gets more traffic.
The spinner/breaker combo I have is an older Oregon made in Italy. Efco I assume. It runs the stubby old style anvil.
