I know it’s not a 6100 but I figured a method with my ported 6400 and 7900. I use the tach to tell when it’s bumping the rev limiter then lean it 1/4 turn past the limiter and adjust if needed after that cutting with it. That usually gets me pretty close with them.
Scott took a bunch of logs and pushed them over the bank.Just went out to the shop to check where it was and I’m 1.5 out. I’ll squeak it in a little bit and try it out in the morning we got to go get some firewood.
I went up and let Steve try it at the shop and made some cuts it was running good and I actually had a good chain on it. I kept worrying that I was going to hit the log in front of it. Lol
nice little performer.Just went out to the shop to check where it was and I’m 1.5 out. I’ll squeak it in a little bit and try it out in the morning we got to go get some firewood.
That a good runner there but you need to but some chap's on them legs Mr not a lot of meet on them thing's.
Good point. I believe you are at 2300’ ASL.Sounds good to me. Elevation difference and stuff....
The Dolmar capital of the universe is at 400 feets ASL. 2,000 feet is a decent difference No?
Yep.......and that's why I like to ask about elevation. I make em a little fat if they are going downhill.
I never touched the screws on the MMWS6100 I got from David Young.
Mater Mind Work Shop 6100? If my assumptions are correct?I never touched the screws on the MMWS6100 I got from David Young.
I think the low side was a little too fat.
Randy, did you ever try some mods to the reed valves to see if you could get them to flow a bit more? I expect a lighter reed would flow a bit more and could lean out that low side richness.
