RI Chevy
- 7:00 AM
- May 7, 2016
- earth
I recently purchased Two of the Pferd 2 in 1 chain file systems from Bailey's. They seemed like a good deal, so I pulled the trigger and got them. I got one in .325 and one in 3/8. About $34.99 each plus shipping.
I had a couple of new Carlton Full Chisel Chains that I had only used for a few cuts, and I was curious to see how these files worked. I was also curious to see if my rakers were high on a new chain. Keep in mind that these chains cut really well, and did not have one stroke done to them to touch up or sharpen them. They were new out of the box chains. So I decided to sharpen these chains. One in .325 Full Chisel and one in 3/8 Full Chisel with this new sharpener.
The sharpener actually was very easy to use and sharpened very well. I did both chains. When I went to use the saws after I used this 2 in 1 filing system, the chains were extremely grabby. Almost to the point that the saws would bog down and stop in the cut. I found out the hard way when I was felling a tree in one of my videos. I knew the rakers were to low.
So needless to say, I wasn't impressed at all with this Pferd 2 in 1 filing system. This is the same as the Stihl 2 in 1 file that is sold by Stihl in orange instead of blue.
In chatting with a few other members, primarily @dall, he also observed the same issue, as he had just recently purchased the Stihl version. We both came up to the same conclusion that the saw chains were too grabby in the wood after sharpening with this new file setup. It took the rakers a little to low while sharpening.
After I used the saws with the chains, I went back, old school, and took a few strokes off of the cutters to see if the chains would get any better. They are slowly coming back and cutting better, with each time I sharpen them with just a file and a simple guide to the teeth. Not sure if I should keep using this, or if I will run into the same issues.
In the past, I used to sharpen the teeth with a basic file guide, and as I noticed the chain not cutting as well, I would take a stroke off each raker as needed. The chain would naturally then cut a little better, and I would repeat this process throughout the life of the chain.
Any thoughts? Anyone here use this Pferd/Stihl 2 in 1 file system? Am I doing something wrong?
I know, I need to learn how to square file. LOL
Thanks in advance for your help.
