old_sir_henry
- 10:43 AM
- Nov 9, 2018
Couple of days ago I wrote
Well this isn't entirely correct. The engines sport some minor differences between 385 and 395, namely the 395 has an
additional mounting bracket for the outer shell which is bolted to 2 connecting threads in the cylinder which are
missing at the 385. That one on the other hand side has a connecting thread cast to the bottom side of the mug, again
to bolt the shell to.
Carbs are different as well: WT-247 (left one) with 395 and WT-20 with 385. Differences are the throttle shaft lever and the arrangement of the idle screw.
Now this is the saw in its final shape:
Engine inside is exactly the same as in the 385 only peripherals are different which make the 395 a backhandle saw.
