wcorey
- 8:43 PM
- Dec 11, 2015
- ma usa
Jms seems to favor heavy transfer mods along with higher crankcase compression. I've seen several times where he ground through to the outside of transfer tunnels and had to use jb weld to seal them back up.
At least some of the reason for that is nothing really special.
When you cut the band and base and raise the exhaust, the transfers typically need to be raised quite a bit and in attempting to just maintain the original roof angles, you simply run out of material and break through the top. Enhancement of the original angles can get really sketchy, particularly on the primary side outside corners.
That the transfers open closer to 90 degrees than the exhaust exacerbates this even further, though it could be counteracted somewhat with more case comp by means of means of more blowdown and/or higher intake...
