- 7:56 AM
- Jan 14, 2016
- North western Ohio
Explain exactly what is a "master" link .It's not like it's a roller chain .
The "master link" is the link that connects the loop back together. OP is shortening a loop. So, he needs to knock out one or more drive links and then reconnect, thus reducing the number of drive links. I usually mark this link with some paint, especially if the number of drive links in the loop is divisible by 4. If so, that means on a typical chain, the number of left cutters equals the number of right cutters. So, when sharpening the chain, the marked link is a pivot point as you are going around.Explain exactly what is a "master" link. It's not like it's a roller chain.
Perhaps a better term than master link might be connecting link. The idea is to connect the ends of a chain together to form a loop. We need to keep things simple.Master link is probably a misnomer since they can't be open and closed repeatedly like one on roller chain, but I'm pretty sure everyone understood what was being referred to. In fact, if done properly, a repair link on a chain should be nearly impossible to locate. (i.e., it should look like all the other links)
When I sharpen chains I just color a tooth with a sharpie. It wears off with use so it's also a way I can tell easily if a chain has already received attention.
we did a few here....well let me correct that, tried to do a few stihl chains with oregon/carlton tie straps. Didnt work as the rivets are larger diameter on the chain we tried to repair. not sure if they are all like that though
Sometimes there is not enough left over.. . . reused the link by peening over with a hammer what was left of the rivet.
I'm guilty of that too.I just re use the preset and tie strap and go on with my day. I have done it many times.
If you're careful to not mangle the tie strap and pre-set when you punch it out, there's usually enough material to spin back down.
I have run into a couple that were not usable, but most are.
'Infidel'!. . . what the purists would say.
