fordf150
- 2:55 PM
- Jan 18, 2016
- Newcomerstown ,Ohio
thats just actual grinding time....setup you can easily add 2 minutes per chain unless they are all the same....and i mean identical. you have to count cutters on every loop and check every loop for double cutters or gaps in cutters so depending on loop size it can add some time just doing that. i didnt include setup time since its new and I still barely know how to run it and have to revisit the instruction manual on almost every chain.That's alot fast than I could do one.
May I ask.....It seems to take a fair amount of a grind at the setting the one in the vid was working at and seemed not to blue the cutter . Is there a air jet cooling the cutter or do you think it comes down to the disk material ? I have to be aware of the amount removed in 1 pass with my pink wheel hand grinder or i can blue the steel.
Learning curve with all new equipment.. . .gonna be a long learning lesson to get this thing down so i can set it up fast and make it do everything its supposed to do.
Ceramic?. . . blue colored wheels are is 10x better than the common pink wheels . . .
I believe so but need to read thru some paperwork to find out. they arent cheap thats for sureCeramic?
Philbert
Ceramic?
