afleetcommand
Freshened up a non running 357. Seals, a new ring, spark plug, fuel line etc....ditched the Walbro (As it would not run with it) and put on a Zama EL-42. Runs fine and will idle until the cows come home. But when you first give it throttle after letting it idle...even a second. It bogs, four strokes a bit before taking off up the RPM range. Like its pooling gas some where.
I notice there is no "notch" in the throttle plate.
First what am I missing??
Second, if this is a common issue; any one try a notch in the throttle plate to help low rpm issues coming off idle?
