- 10:09 AM
- Jan 17, 2016
Love the Dolly Howard!
Hey erryone.
Thought I’d bring in a little sunshine.
Katie Sunshine that is.
Love the Dolly Shad!
Hey erryone.
...hmmmmmSpent a little more than an hour out in the blowing snow working with neighbours to clear the snow. Some guys are too eager and we're going to have to do it again as it is still falling / blowing...
Chit talkingThat when you make yourself a cocktail and channel your inner Ron White and start chit talking and the futilely of their actions.
Jason! When you refinished your headlights did you wet sand and use rubbing compound with a buffer attachment or did you use a kit? I gotta do mine and wanna know what to grab.
Used a Meguiar’s Heavy Duty Kit that I’ve had. Yes to the wet sanding first...kit has a 3” P1000 grit pad and a P3000 grit pad that hook and loops onto a hand scrubbing pad attachment, clean left to right with the 1000 grit pad, then up and down with the 3000 grit pad, keeping the surface wet with a spray bottle of water, wiping dry btwn grit changes. Then use the buffer pad that goes into a corded/cordless drill with the PlastX cleaner and polishing cream. After a couple of runs with the buffing pad, wiping it off before it dries on, apply a couple of coats of the UV Protectant. Can tape off and do a set of headlights in an hour. And your done with ‘em. Plenty of kits out there, some a third of the price as others, and will give you the same results as the highe priced ones. This kit was $20 a year or so ago, this is the third set of headlights it’s done.
If you have to wet sand that tint/layer off, might wanna pick up some more 1000, 3000 grit pads if they have them locally, I’m sure the auto part stores do. Might be wise to go with 800 or so grit pads to begin with going after that tint layer...you’ll just have to see how the kit pads work and maybe re-group.Awesome, I'll be picking up that kit! I appreciate it, I gotta do my mother's as well so kit it is. I did them about 2 years ago and tinted over them so I gotta bring the old tint up too, it's starting to flake. And that's cool about the @Czed motor oil trick, never knew that, good to know and keep as a back up!
Hell yah it looks great! I finally got a 550 back together and cutting tonight. Should get another together in the morning and then I'll get my 394 on the bench.This bish is ready for fuel and a few heat cycles. Maybe tomorrow if I feel up to it.View attachment 219254 View attachment 219256
Thanks Tim. Looking forward to your build as well.Hell yah it looks great! I finally got a 550 back together and cutting tonight. Should get another together in the morning and then I'll get my 394 on the bench.
View attachment 219266 View attachment 219267
Send it my way I'll break it in good for yeahThis bish is ready for fuel and a few heat cycles. Maybe tomorrow if I feel up to it.View attachment 219254 View attachment 219256
Yours right?2100CD is going back together tonight.
YupYours right?
