NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
AlfA01
6:56 PM
Evia, Greece
What's up mathafakiedes (that's Greek for mofos)? Cool and cloudy today.
Tipped over a few more trees. Cut a wild SOB tree today that wanted to set back on the stump. It leaned one way, but had a high heavy limb in the opposite direction.
Y'all have a good one.
Lil' Jonny fought the pine tree, and Lil' Jonny won....
This one is waking up woke and running like a champ! @Stump Shot props to you brother. Lil' Jonny ain't naughty....he's down right nasty!
Eye see....
This Echo ain't bad either...I modded the muffkin yesterday and took it for spin today. I like it...
The view today....there's snow right where those clouds are sitting.
Sea view...
Disciple of Monkey's
11:56 AM
Eye see....
Sea view...
Good to hear about Lil' Jonny.
Nudder bad Jonny project in the works... Jonny Ringo.
USMC615
Fapper Fi
12:56 PM
Mid-Georgia
Eye see....
Sea view...
Yer gonna run outta trees to cut...:cunaooooo:
12:56 PM
Sup slackomatics?
Jason! When you refinished your headlights did you wet sand and use rubbing compound with a buffer attachment or did you use a kit? I gotta do mine and wanna know what to grab.
used motor oil and a rag is all you need.
12:56 PM
good afternoon guy's
11:56 AM
Sup slackomatics?
It's the same treatment he gives the ladies headlights. Lol
USMC615
Fapper Fi
12:56 PM
Mid-Georgia
Sup slackomatics
Used a Meguiar’s Heavy Duty Kit that I’ve had. Yes to the wet sanding first...kit has a 3” P1000 grit pad and a P3000 grit pad that hook and loops onto a hand scrubbing pad attachment, clean left to right with the 1000 grit pad, then up and down with the 3000 grit pad, keeping the surface wet with a spray bottle of water, wiping dry btwn grit changes. Then use the buffer pad that goes into a corded/cordless drill with the PlastX cleaner and polishing cream. After a couple of runs with the buffing pad, wiping it off before it dries on, apply a couple of coats of the UV Protectant. Can tape off and do a set of headlights in an hour. And your done with ‘em. Plenty of kits out there, some a third of the price as others, and will give you the same results as the highe priced ones. This kit was $20 a year or so ago, this is the third set of headlights it’s done.
USMC615
Fapper Fi
12:56 PM
Mid-Georgia
Sup slackomatics?
Now you can run Dave’s theory as well, can use new motor oil or used...but you’ll be doing that method of madness at least every two weeks. One of the oldest used car lot tricks used car salesmen ever invented. Juss sayin...
Status
