Nighthunter
- 1:01 AM
- Feb 18, 2018
- Tipperary Ireland
Imho never hone a cylinder
A is ok in a B bore/B is ok in a A bore. You probably wouldn’t want to put a C piston in a A bore.I would replace the piston and run that cylinder after a cleaning with scotchbrite or sand paper. Some cylinders are marked “A” or “B”, this denotes the bore size and the corresponding piston that should be used. Make sure you get the correct piston for your cylinder. An “A” piston is slightly smaller than a “B”, so you can see where problems could arise, especially with a cylinder with some miles on it like yours.
I really like that flywheel knocker you made, much betterer than my drift method.
They did when I ordered a 262 piston a couple years back.Well I will scotchbrite and ordering a piston for this cylinder. I'm pretty sure it's stamped "A" but I will have to check tonight.
Does anyone know if meteor has a notation for "a or b" when ordering?
Also I will probably still order a new p/c kit for this saw. Do you guys know if HL supply's oem kit is mahle?
The new oem top ends are KS. Not sure if Hl has them or not. @Spike60 or @Onan18 can take care of you though for sure. Oh and dibz on the old cylinder lol.Well I will scotchbrite and ordering a piston for this cylinder. I'm pretty sure it's stamped "A" but I will have to check tonight.
From what I have seen they are pretty close to the mahle decomp cylinder.The new ones are KS? How do they compare to the older cylinders? Mine is an untapped Mahle decomp.
Sent from my SM-S327VL using Tapatalk
Thanks for the info.
I disagree for this instance. The cylinder is serviceable but worn. I wouldn’t want an A piston in a B bore in this case. All things being new, I agree 100%.A is ok in a B bore/B is ok in a A bore. You probably wouldn’t want to put a C piston in a A bore.
Yes sir I’ve got no complaints at all with my new production KS. I haven’t ported it yet because I’m happy with how it runs.Yeah the new oem is definitely a better option than aftermarket especially for the price. @XP_Slinger has one on his, and can tell you all about it.
I was thinking the same. But I'm new....lolI disagree for this instance. The cylinder is serviceable but worn. I wouldn’t want an A piston in a B bore in this case. All things being new, I agree 100%.
Lol! New don’t mean nothing bud.I was thinking the same. But I'm new....lol
That’s tough. If it were me I think I’d leave the Mahle stock and do my grinding on the KS. Those old non-decomp Mahle cylinders are becoming a little difficult to find except for a few members here that have a horde of them.So question.
Port the old worn Mahle and keep KS Stock or vis vers....?
I think you may have the names mixed up, maybe not (I'm still new to this) but if I recall the older KS non-decomps are like hens teeth and run stronger. My brother has 2 ( lucky bugger ) and it definately runs stronger than the mahle on my saw due to the smaller combustion chamber.That’s tough. If it were me I think I’d leave the Mahle stock and do my grinding on the KS. Those old non-decomp Mahle cylinders are becoming a little difficult to find except for a few members here that have a horde of them.
