- 3:19 AM
- Dec 30, 2015
- Brewster, NY
It started that we were going to do a MS460 project, then realized it would make a great Hybrid, and so it morphed. Dr Al currently has the P+C (see pics) and I installed a OEM 044 12mm crank into an Asian case today. This saw will be a blend of Asian and OEM parts. The OEM will include the crank, piston pin + bearing, cylinder, chain adjuster, winter filter, and perhaps the coil (if it works).
The case, tank holder, plastics, oiler, clutch and most rubber will be Asian.
Al's Wizardry with the P+C should make this one special!
