r7000
Rebuilding an older Stihl 029, unknown hours, friends saw I used it 5 minutes idled great, shut off never restarted, starting fluid would get a 1/2 second kick at best, and could hear rubber squeak pfft when pulling cord so i assume crank seals or pan seal let go.
The saw is/was in excellent condition, ignition coil tests fine, pretty sure carb is good non-ethanol gas used for a long time and engine ran perfect just never restarted. Doing a compression test i could get it up to 140-150 psi max, would hit 70-90 psi on one pull of the cord.
I have everything apart and new seals on the way, but since this far in looking for advice if I should do a new cylinder and/or piston kit? If so, can I reuse the existing crank pan?
The existing piston diameter, above the top ring measures 44.78mm. Measuring the ring outside diam compressing with my calipers i can get it down to 45mm. So how can i best tell if the saw was a 45mm 029, or a 46mm 029? And I kinda want to just do a new cylinder and just rings reuse existing piston everything looks fine, is that good/bad/not advisable?
If i go a big bore kit I assume the 49mm one is the largest and the one to go with? In any case if going larger than my existing since we are talking < 5mm difference can the existing crank pan be reused (looks hard to remove from saw shell) and
if I do a larger piston + cylinder on existing crank assembly does new piston weight matter, will there be an imbalance at 10k rpms, is that something that needs to be accounted for when retrofitting? I do have a good gram scale and i am not new to balancing stuff like this.
