A great idea. Now if they can invent something for the pump diaphragm. Although, I think most of the problems associated with the pump diaphragm are a result of the small diaphragm over the 'pulse' chamber getting worn out.
The next time I have one that is showing deformation I'm going to try a small metering spring under that part of the diaphragm to see if it cleans up the idle.
