never any luck with my Husky 345
Matt Segal
New OPE Member
12:18 PM
CT
its always seems to have a tune issue, and the H fuel screw never seems to make it diesel ???
dougand3
11:18 AM
North Alabama
Carb could be dirty inside or stiff diaphragms. Tune the L screw to "4 stroke" before you tune the H screw. Also, an air leak around carb, base gasket, crank seals can cause saw never able to tune in.
iridevfr
OPE Member
11:18 AM
NE OK
Ran a compression test on the saw? I've had a hard time tuning them if they aren't within spec on compression. Anything less than 90psi and you'll likely need new ring(s).
Jimmy in NC
12:18 PM
North Carolina
If you have the high speed more than 2 turns out you have major issues. Looks for an air leak as others have said.
One thing...I find hearing protection helps me to hear a saw "4 stroke" easier, especially the small saws.
Ogre4500
12:18 PM
My 350 was giving me problems keeping tune and no power in the cut. Found low compression, 105 psi. Installed an aftermarket 346 top end and the saws never been better.
d.l.d
11:18 AM
Arkansas
Sounds like an air leak as someone else said. This series of saw has that crappy intake boot clamp made of plastic. (until the updated metal one came out) I've seen a lot of them toasted because of it. also where the carb mates to the intake boot leaks especially if someone has tightened the carb bolts too tight. And the bearing cup where it mates the plastic case. Thats where I'd check for your problem if your carb diaphragms are good.
KZ1000
12:18 PM
Ohio
I'm just here to watch do that I know how to handle problems with the one that I win.:cool:
NorthcentralYooper
12:18 PM
Upper michigan
I'm guessing a air leak like stated before , check bottom of the carb boot , they Crack there often. I would also clean carb . I wouldn't recommend running it in this condition.
cgraham1
9:18 AM
Nor Cal
Rebuild the carb, and check the fuel line... and if it has the plastic intake clamp, that may be an issue, as well.
cgraham1
9:18 AM
Nor Cal
I was thinking about the 346xp/353 saws. Not sure how much they have in common with the 345.
