- 9:53 AM
- Jun 5, 2016
- Northwoods of Wisconsin
Yes, 12volt DC motor, it does have a gear reduction on it. I would think with right sprockets you could get it to the right speed like you did for your set. This just works of a chain similar to how your set works, just back and forth instead of round and round. Ends of chain have eye bolts used as tensioner. Chain goes over sprocket down to two idlers, one going each way. Has a two way switch for forward and reverse with stop in the middle. Then there is a knob that sets the speed it's like how a dimmer switch on old cars used to be, where you turn it up or down to give it more or less voltage. Relatively simple set up, and all works off of the battery and is charged by the motor. So when I'm sawing I can dial in the feed that works best and it stays steady, on the return trip turn it wide open to get to the next cut quickly. Pictures can probably tell the story better than I can. If you have any questions please feel free to ask, I'll try to answer best I can.
