When you and your brother were about the ONLY Ford guys in the area, YOU REMEMBERED EVERYTHING!
Keep in mind, back then, no aftermarket heads, etc, etc. You had to keep track of what parts interchanged, and what parts did not, and Fords were tough! For example, I ran 428 SCJ heads on my 427 Low Riser, they would not have worked on a Medium Riser or High Riser (they had larger compression chambers). The 428 heads had the same valves and combustion chamber as a low riser 427, but with 427 Medium Riser Ports.
The 429/460 was a whole different engine family, nothing interchanged with the earlier FE engines.
351 engines had the same bore spacing as 289/302, so you could steal the heads (and use pop up pistons), but the 351 Windsor engines had the same water ports, 351 Cleveland heads did not, so you would have to drill them to use them. 302 Boss heads were basically 351 Cleveland 4 bbl heads (the 2 bbl heads were smaller), but with windsor water ports to work on the Boss 302.
Lee, those ports are HUGE, you could block them half off and still would need more carb to use em!
When I got the 427 short block for $300, the guy had a set of Tunnel Port 427 heads, huge oval intakes with the push rod sleeves going right through the middle of them. But he wanted $1,500 for them, and that was unaffordable to me.
Factoid! Almost all FE blocks were stamped "352" including my 427!
FYI, that 427 short block was a 1966 cross bolted main, side oiler, Holman & Moody seasoned block with the crank trued (cut 10 & 20, I found out the hard way after I ordered bearings for it). You could ONLY run a solid lifter cam in it, was not drilled for hydraulic lifters.
