Buy Used Saws CCC Ebay Store
My 066 build, I call it Big Dee...
Discussion in 'Sub-forum for these Rice Burner 660 builds' started by MS290man, Apr 30, 2018.
  1. MS290man
    MS290man Super OPE Member
    Jul 6, 2016
    230
    596
    138
    Texas
    I finally got around to putting together my 066 kit from Huztl. I bought this about 3 months after they started selling full kits so I guess I got an early one. I decided to go with OEM gaskets, seals, oil and gas caps, intake and impulse line and sprung for the AM big bore kit. I used the special crank tools from Mattyo (awesome, btw) and building the case was easier than I expected. One thing I noticed was that the powder coat was not consistent; way thick in some spots, non-existent in others. Not really a concern, until I got to the bar tensioner. After 2 hours of fiddle farting around and cleaning out literally gobs of powdercoat I was able to fit the tensioner components.
    Most everything was organized in bags according to the specific assembly section which was a plus. Lots of duplicate rubber parts; a lot of them were already installed so I wound up with seconds.
    I flooded the saw initially (brain fart), but once I cleared it I only had to make minor adjustments to get her to run.
    She’ll wear a Sugi 25” bar but not till I’m ready for test cuts (need to source a new test log).
  2. MustangMike
    MustangMike Mastermind Approved!
    7,776
    22,666
    513
    Did you do any work to the jug?
    Let us know how it runs.
  3. Wonkydonkey
    Wonkydonkey Pinnacle OPE Member
    May 14, 2017
    888
    1,866
    208
    Nearly in the middle of know where
    Nice cover on the clutch cover
  4. smokey7
    smokey7 Pinnacle OPE Member
    Feb 3, 2016
    1,165
    2,642
    275
    Detroit
    Yes let us know how the big bore jug turns out. I had 1 of 4 that was literally perfect. No free port by .020 squish was flat and consistant at .028 timing was decent at 99 122 82 and ports were shaped and chamfered pretty decent for a 30 doller kit. Of the others i got from the same vendor either had terrible plating, huge free port, squish the wrong angle, and one even came with a 440 piston and a 56mm jug
    Ron660, redpete79 and MustangMike like this.
  5. brshephard
    brshephard Stihl saws, Husky women
    Apr 7, 2018
    156
    396
    108
    MT
    How does that big bore run? Did you get more vibes with the heavier cylinder?
  6. smokey7
    Feb 3, 2016
    1,165
    2,642
    275
    Detroit
    Runs very very well. Not as high reving as a oem 54mm by about 800-1000 rpms. But she is a grunter. Pulls its 36 inch full comp stumping for a tree service. The tree guys crushed the oem broke about all the fins off. So it got put back together with all aftermarked parts atleast 3 years ago. Definitive dave sent me a koyo wrist pin bearing to try that is also still in service. I heard he had trouble with them on some real hot saws. Long story short i knew i was buying cheap parts and was on a time line so i ordered 4 p&c kits knowing some would be junk. Low and behold one was just exceptional. I was able to return the other 3 and got my money back. The build is just a freak runs at 12500 all day on their 50:1 redmax oil with 87 corn gas. Everytime they drop off another saw to be fixed i ask them about its health of that saw. They say other then being tough to pull over they would die before i got it from them they love it. It has lasted way longer then i thought it would.
    bottlefed, Ron660, blacksmith and 3 others like this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
