Redfin
Meh...
- 3:29 PM
- Dec 24, 2015
- Central Pa
About to mod a couple 044 mufflers. Mine will have a duel port cover on it and was thinking of opening the factory hole to the size of the deflecter on the side. Any ideas?
Hey if you are looking for bigger pieces of spark screen then did them out of the Poulan wildthing on wood sharks
Nice job on the muffler
Check in with @VinceGU05 he does a great gill type modHas anyone done a how to on the fish gill type mod?
It looks pretty straight forward. But I bet it could be screwed up easily as well.
I'm wanting to do my 261c
Awesome pipe thereNot anymore I don't but I cut mine in half gutted the baffle out and installed a bigger diameter tube in it. Ran real nice. This is the muffler mod now on my cs 510 49ccView attachment 27216
More steel outa the muffler than in it Great job on the mod though looks greatI chowdered the guts in this stubborn chunk of 075/076 steel.
I was lucky this came from the factory with welding that completely filled the entire area behind the flange so I was able to hog out the inside to match the exhaust. There's another next to it for comparison.
Here it is all purdied up and such..
Approximately how long did it take to do the modThe top cover was then trimmed to fit on and protect the front port.
I think it will breath and sound better!
couple hours work I guess.Approximately how long did it take to do the mod
I used Nutserts.Did you weld nuts on your 261 muffler on the inside? Or is the metal thick enough to tap?
yours looks good and I want to do one myself.
Thank it's a moped pipe and also has a glass filled silencer that bolts onAwesome pipe there
Crome would look cool too once it got blued. But yeah stove paint works goodWhat do you guys use for muffler paint. I got some heat paint for woodstoves left over. Think it would work?
