MS462 FOR SALE IN GERMANY
cgraham1
1:47 AM
Nor Cal
The new STIHL MS 462 C-M chain saw...
Its engine weight of only 6 kg makes it the lightest high-performance saw in its displacement class (70 cm3).
Technical specifications:
Engine: 2-MIX engine
Displacement (cm3): 72.2
Power (kW / hp): 4.4 / 6.0
Engine weight (kg): * 6,0 (13.2 lbs.)
System weight (kg): ** 7.6 (16.8 lbs.)
Power weight (kg / kW): 1.4
Features: M-Tronic (M), ElastoStart, decompression valve, stop button
* Without guide rail and saw chain;
** Equipped with guide rail (STIHL Rollomatic ES Light 50 cm and chain STIHL 3/8 "Rapid Super);
maulhead
2:47 AM
best get your 461's while you still can!
461's will be around a while, they ain't silly enough to drop a classic tried and true saw, for some spring loaded, computer controlled, untested new finagled model, 1st they are going to have the public guinea pig it for them, to see what updates it needs.
Watch for the updated....#intake boot#coils#clutch covers#solenoid#cylinder#etc
RI Chevy
4:47 AM
earth
Come on now. Think positive! [emoji106]
CapitaineHaddoc
I don't eat frogs
9:47 AM
FRANCE
4:47 AM
View attachment 80292 Weighs a pound less than the old MS460 with the same advertised power. Weighs about the same as the 440. Might be kind of like a Hybrid.
I wonder dimensionally how it will compare in size?
The posted weights on the MS440 and MS460 are incorrect. In the real world, the 440 is about 14 lbs, and the 460 about 14.75, power head only. The 362-C is 13 lbs.
Hopefully, the posted weight of the new 462 is not an exaggeration, but we will see.
I have also seen old Stihl specs that stated the 044 was 13 lbs, complete BS!
maulhead
2:47 AM
Not to far off...
10mm 044
dscn5932-jpg.30183
