Stackowood
- 9:24 AM
- Dec 17, 2016
- West coast
I have a MS461 that a customer brought in for low power. 2015 model, fairly low hours 28" bar, great looking piston, all stock, 160 psi, passed pressure check, starts fine, runs fine at no load, set at about 13,200 rpm.
When it came in the air filter and fuel filter were plugged. Replaced plug and fuel filter, cleaned the air filter, replaced the fuel tank vent, and it still has low power even when testing with a 20" bar. It doesn't die in the cut, but you can stop the chain. Have not replaced the lines but they look fine.
Any thoughts on what to look for besides the obvious? Note picture of spark plug. Thanks!
