SixGun
- 5:09 AM
- Jan 8, 2016
- Hackettstown NJ
Customer had idle problem since new, brought me the saw and it would start fine but would only idle for a few seconds and die. No adjustments on this carb so I tried the reset procedure and it got worse. Did some research and found out that the tiny solenoid on low side goes bad sometimes. Changed solenoid , did reset and problem solved. Very easy fix. Pics of solenoid and part number. Hope this can help someone out.
