PogoInTheWoods
- 1:50 AM
- Apr 23, 2016
- Ohio
I have a MS362 on the bench that starts and runs from high idle on up but won't idle..., period. Has a Walbro WTE-8 carb with accelerator pump and the diaphragms still look decent. It's also only blowing 128psi of compression though the piston and rings look new through the exhaust port.
Anyone experience accelerator pump issues with this carb (similar to the 200T Zamas)?
I'm also thinking maybe the low secondary compression at less than 130psi could result in the primary compression being too low to create enough impulse to drive the pump diaphragm at idle. FWIW, the carb has the amber (teflon?) pump diaphragm which I believe is the most flexible of the ones I'm familiar with (blue, black, clear, amber).
I have no idea what the compression should be on a MS362 but I'm guessing 160 ~170 (and the decomp is there for a reason).
Thanks in advance for any input or enlightenment.
