Cracker Boy
Fl cracker
- 6:29 AM
- May 31, 2016
- Florida
Oem parts= carb kit/ impuse line/ clutch springs/ piston rings/ wrist pin bearing/ cylinder base gasket/ fuel line/ fuel filter/ crank bearings/ crank seals/ case gasket/ aftermarket parts= bar oil plate / clutch cover/ oregon 8 tooth 3/8 rim sprocket/ front av mount saw has been press tested and vacum tested.shes a pretty clean saw 600 shipped
