jb-chainsaws
i don't suppose anyone knows the part number for an Ms200t impulse line? Can't find it in my IPL, maybe It's just me being tired but can't for the life in me find it. Any help would be greatly appreciated.
Yes I see. I had a look at a newer IPL. My opinion is: Your picture is from an old IPL and this hose is maybe a pre EPA standart fuel hose that was used in the past and doesn`t meet current permeation guidlines. (I`m not sure but it can be) With EPA standart changes, they switched to a other hose to meet the new guidelines.
Best answer, lol
http://www.sawagain.com/stihl-ms-200t-020t-impulse-line-new-11291418600/Impulse hose must be cut to lengh from hose 0000 930 2803 (hose 3,1x5,7 mm x 1 m, R3). You need a piece with 102mm.
Attention:
The number above this post (1129 141 8600) doesn`t belong to the MS 200, 200T, it is a hose on a TS 460 tank vent.
2012 was the change in all fuel lines. They had to switch to "low permeation" fuel line on anything exposed to the atmosphere. If the hose is "low permeation" it should have markings on it labeling it as epa line....At this point saying that this hose was not used on the MS 200, 200T, I was wrong. Excuse me. The IPL I had a look at it showed the other (newer) hose. I really think they switched the hose because of EPA regulations. Somewhere I did read about it.
