SteveSr
- 7:13 AM
- Dec 14, 2016
- North Carolina
Hello,
I have both a 170 & 180 that have been recently overhauled/rebuilt. Rubber has been replaced and bot passed leak test. Both are about 10 years old and needed carbs for different reasons. I bought 2 Stihl OEM carbs and installed them.
On the first test run @45F the 180 ran 14.2K and the 170 at 15K! I also noticed that the LA screw didn't have much effect on the idle speed except to lower it. I did some investigation and found that contrary to Stihl's 5/2018 IPL that 0.44 fixed jet had been installed instead of the specified 0.45.
So I took the 0.45 jets out of the old carbs, cleaned them, and installed them in the new carbs. I test ran both saws again today at the approximate same ambient temperature. The fixed jet change made a significant increase in idle speed which had to be adjusted down. However, much to my surprise, the WOT speeds remained the same!
@backhoelover or any other carb experts explain why changing the fixed jet had no discernible effect on the max speed of both of these saws? I would have expected it to richen it up enough to at least see a measurable decrease in the max RPM. Why did the jet change appear to effect the low end? I thought that the idle circuit was separate and fed from a fixed orifice under the metering lever arm.
I work on these (and other) saws as part of a state wide volunteer trail organization so I won't be the end user and the saw may end up at the other end of the state where I won't have access to it to monitor. I hate to send these out running so fast that they might destroy themselves but I also can't change to adjustable carbs and turn them into Frankensaws as I likely won't be the one doing any possible repair work on it.
Any suggestions on how to proceed?
Thanks,
Steve
Thanks,
Steve
