Stihl working Hard
Is it Friday yet
- 10:39 PM
- Feb 6, 2016
- Perth Australia
Interesting Scott I wasn’t aware you could hone a chrome Bore learn something every dayI use the same set of rings for all the testing, I also make sure that port timing is the same with all pistons. top ring is always the top ring, same with the bottom ring. most rings are cast and easy to break, I don't think fatigue is a problem. I don't usually change rings when i'm done, but will hone the cylinder if I do.
