tree monkey
it does like it's fuel
No shìt....it does make a difference
epoxy in the transfers now, will be testing again in the morning
I see your thinking. I know this has been tested before....This a great thread - as others have stated before. I have a question for you guys. I always thought the idea behind scavenging the cylinder was to direct the fresh charge towards the back of the cylinder first - essentially filling the cylinder with fresh charge from back to front, while displacing the spent charge and by default directing it out the front of the cylinder. If this is the theory, wouldn't it be better to open the secondaries first? I would think that by opening the primaries first you may be actually trapping a portion of the spent gasses in the back of the cylinder, then when the secondaries open, a pressure wave is formed that could force the primary charge out the front of the cylinder, with the trapped spent gasses coming behind it. In actuality, it would more likely be a mixer of fresh primary charge and spent gasses combined, which is not ideal either.
I would think that by opening the secondaries first, the back of the cylinder would be filled with fresh charge initially, directing the spent charge up and forward. Then, when the primaries opened, they would combine with fresh charge at the rear of the cylinder, while simultaneously contributing to pushing the spent gasses up and forward. This would also contribute to a denser/cleaner incoming charge, and less combining with the spent charge.
Thoughts?
I know you are strapped for time, will you test with the plug in the same orientation first to see any changes, than index the plug and try again? Or all at once for the sake of time?
all at once, about out of wood also. just hope to hell it don't go back words.
It’s not popping yet, so it’s not quite maxxed out yetDid you epoxy both sides? Can’t imagine a better angle towards the intake can hurt, but if it does it shouldn’t be too hard to dig it back out.
I believe you are very close to calling this maxxed out!!!!! [emoji23]
Plus it’s good enough for who it’s for...
^It’s not popping yet, so it’s not quite maxxed out yet
Wow, a lot has gone on here. Lots of good thoughts.
Scott, how are you confirming that the coking of the piston crown ain’t being burned off by the flame front by the plug indexing? Could be affecting pattern and misleading everyone.
Obviously index plug. Look at pattern.
Looks like tons of oil, do you think 40:1 would work better? It would also increase the octane, which cant hurt!
Personally I'd stick with 32:1 at high rpmMike, reducing the oil would make the mix more volatile, which is a lower octane. Which unless it started detonating could be a good thing.
Probably what you meant.
Milliseconds do count, but the saw still has to live
