MS 251C missing part
Christian Beyrend
Active OPE Member
6:02 AM
Canada
I am back already, with a new question.
I am almost down re-build an MS 251C. Everything is back together, the saw is running good, except one piece is missing.
I do not have any idea how it look like and if I have only one or more pieces to connect between the switch and the carburetor. This piece supposed to close a butterfly when you chock the saw for the first start.
I need to give at my bosse, a reference, a name, something for him to be able to order the missing part(s).
Did someone has one of this detail "part diagram", or the part name?
Thank you
backhoelover
SERVICE MANUAL MASTER
6:02 AM
lincolnton nc
if that is what you are talking about there is a tech bulletin. there is 2 different linkage you will have to found out what carb is on the unit and then the tech bulletin will tell you what linkage to order
  • ms 251 choke linkage.pdf
backhoelover
6:02 AM
lincolnton nc
need to get the saw back and find the numbers on the saw unless you remember them from working on it
Christian Beyrend
Active OPE Member
6:02 AM
Canada
on the carb i mean
Thank you for all the informations. It look like I may have to part. The one I have look like the one on the doc you sent to me. The only thing is I am pretty sure it come from an MS 261, and I did try it once with out success.
Fish
6:02 AM
Manton Ky.
Here is the part off of a MS251.
