Which fuel/oil ratio are you using (50:1 or 25:1)? If you use for example 25:1 and your carb isn`t tuned right it can smoke. Also is your carburetor tuned right? Don`t do it by yourself if you don`t know what exactly (depending on the situation) to do. You muffler can also smoke if it is oily from bar oil when it gets hot.
