7900 oiler on the chopping block. Steepened the ramp by .010-.015. Hope to oil a 32”er good. Very easy to mod this one. The end screws out and everything comes apart pretty much.View attachment 141455
That is next or will it be fine with a 3/8 050 28"?7900 oiler on the chopping block. Steepened the ramp by .010-.015. Hope to oil a 32”er good. Very easy to mod this one. The end screws out and everything comes apart pretty much.View attachment 141455
That's two worms down and one done-for pump piston/gear.
Who has worm gears laying around?
I'm getting behind on them. Most of you replace the whole gear and spring. Soon I'll have enough carnage parts to build a completely worthless pump
That first one put out like a hose with double the volume
32” .063 3/8 or a .050 28” 3/8 is what I’m hoping. Oil consumption is 1/1 with the gas now after the mod.That is next or will it be fine with a 3/8 050 28"?
Not a bad idea but everything has a weak link. You need that to be cheap most times while testing.Sounds like you need one made of brass lol.
Most of my bars over 24 to mill with are 404.I milled with one of my 7900 with a 110DL Oregon lightweight bar without issues. I use 063” bars over 24”.
You have to mod both imoMy apologies for waking up an old thread.
I am curious why so many believe that modifying the control screw increases oil output?
Iirc the cam controls pump stroke and THAT is the key to increased oiling.
I believe this applies to Stihl and Husky oilers.
Cheers lads
Depends on the brand of pump. You can add all the ramp angle in the world to a Stihl pump but it won’t flow much more oil until the cam on the control bolt allows the plunger to travel fartherMy apologies for waking up an old thread.
Cheers lads
because the factory HIGH OUTPUT pump designed like that.My apologies for waking up an old thread.
Cheers lads
Cheers lads
From my experience on modafying pumps is sometimes you only need to modify one or the other to increase output it all depends on brand and make sometimes you just have to mod both pole one apart and study it really good watch where the to meet up sofar I've seen nun of them are perfect and while modify one baby steps are key otherwise you're just wasting time and money.My apologies for waking up an old thread.
Cheers lads
