I haven't compared to 7900 piston Josh. Do you have one not on a saw to get some measurements?Have you evaluated the 7900 or any other models as piston donors?
I don't think 85 is anywhere near too much intake on a cant racing saw.
Skirt wise the 064 is a tad wider than stock correct JJ? Other than that they are pretty similar from what I can recall other than rings and ring ends and of course pin bosses. Crown height was .015 or so difference.The crown height on a 7900 piston is quite a bit lower than either a 475 or 272 piston. I built a strong 2077 once with a Stihl 064 piston.
7900 piston would take a mile then to get where it needed to be.The crown height on a 7900 piston is quite a bit lower than either a 475 or 272 piston. I built a strong 2077 once with a Stihl 064 piston.
He's on facebook. 046 requires 2 gaskets and a 16 gauge spacer. 272 needs about .125" spacer on a 7900Skirt wise the 064 is a tad wider than stock correct JJ? Other than that they are pretty similar from what I can recall other than rings and ring ends and of course pin bosses. Crown height was .015 or so difference.
272 skirts allow for wider ports.
JJ does anybody still talk to Tommy Fales or know how to get in touch with him?
