Vancouver timber
- 11:11 PM
- Jul 31, 2019
- Canada
Saw has a brand new OEM stihl piston installed the cylinder is used but it didnt even have aluminum transfer on it so just very light brake cylinder honing was done and checked the culinder bore to make sure it was true. New top end bearing new set of seals base gasket delete like I do to all my saws I have the top ends off. New crank case gasket new muffler heat shield tape. New plug new air filter and pre filter nos af cover , rebuilt the carb cleaned the hell out of It and I'm sure I'm missing lots will update as it comes to me but the saw oils as it should starts funs and idles as it should as well as had a healthy bottom end, very responsive. This saw is both quite attractive and performed like a champ Its a stihl 064 w what more need I say?
