MattG
Chainosaurus Rex
- 2:20 PM
- Apr 30, 2017
- Cambridgeshire, England
Hi people,
So I went about setting/checking the squish band on my latest 200T. Before I measured it I noticed slight carbon build up on the top of the jug, which after quickly polishing off I noticed some strange artefacts, basically very slight raised areas around the edge....which (on another forum) I was informed are due to the bosses (or something) inherent in the casting process. You can see them right here:
These peripheral areas are detectable with your finger nail, and seem to protrude out by a fraction of a mil.
Anyway, seeing as the squish I approximately measured with the base gasket fitted was around 0.040", I decided to remove the gasket, and measure it more accurately with 4 pieces of solder, pushed quite close to the edge i.e.
You can see on the pic above that solder is squashed more at the periphery when moulding marks protrude. Note that this slightly protruding area is about 2mm wide (except those 4 D-shaped areas which must be ~4mm).
When I measure the 4 pieces of solder, I'm seeing about 0.013-0.014 for the areas where the moulding bosses protrude, and about 0.021-0.022 in the main part of the squish area.
What to do? Should I accept these annoying protruding areas and add 0.005 of gasket....or given seeing as the engine is only 35cc and that the protrusions are right near to the edge, ignore them and just run it like this?
All advice appreciated, Matt
