- 5:17 PM
- Dec 24, 2015
- Coastal Oregon
Are those Terry's proprietary cap bolts? They look good.
Copy, he’s using the SP rod then, they are actually a pretty beefy rod, I have a few that are in really good shape! With the new rod, it must be a smidge taller than the stock rod that I had before, the piston is sitting up slightly out of the hole, which is fine for squish because of the head gasket that I use, and it will reduce some port timing, which I’m excited about I need to talk to him about that in the future if he can make the piston crown a little taller to give the saw more torqueNot going to lie, I was a little bummed when he said my rod was okay lol. Looks good glad to see you back at it.
Yes I believe so! I have been looking at then an they look nice! It’s the first time I’ve seen them, he has sent a few different rod bolts over the years but these look differentAre those Terry's proprietary cap bolts? They look good.
Yes sir, he makes them! He has some different thicknesses tooDoes Terry have new copper ring head gaskets? I need to get a couple-three of those.
Those look like aerospace grade titanium tapered head bolts. Half the weight and stronger then most steel.Yes I believe so! I have been looking at then an they look nice! It’s the first time I’ve seen them, he has sent a few different rod bolts over the years but these look different
That’s cool, I am not sure on these, I will have to ask Terry, I checked them with a magnet and it’s not as strong of a pull as the steel, is your ti magnetic? Ti isn’t suppose to be magnetic, so I am doubtfulI'm swapping out my crankcase bolts with these M6 titanium.
The button heads will hold the sideplates to the crankcase.
View attachment 201760 View attachment 201761
I just went out to the shed and tried picking up one of the bolts with a 066 flywheel magnet. The magnet couldn't pick up the 6mm cap screw bolt but moved it a wee little bit.That’s cool, I am not sure on these, I will have to ask Terry, I checked them with a magnet and it’s not as strong of a pull as the steel, is your ti magnetic? Ti isn’t suppose to be magnetic, so I am doubtful
Been there, done that a couple of times. That was probably the only issue with the kart to saw conversion.The 101 blocks don’t have a hole for the manual Oiler. I use the stuffer or gasket to locate, a 1/4 hole all the way through and a 15/64 is the drill size for the seal. Some blocks have different size “boss” for the pto side bearing, you can extend the 1/4 hole to relieve the area need for the manual Oiler pushrod or use a rotary file View attachment 202476
Here is the factory 125View attachment 202477
Here is a stock 101aa block View attachment 202478
And the bottom of a cp125View attachment 202479View attachment 202480
