- 11:14 AM
- Dec 3, 2015
- Banner Springs Tennessee
Meanest 60cc saw ever? Maybe.....
Is there an aftermarket reed that would fit the 6100? I doubt V Force......possibly Boysen?Has anybody checked out the reed block and seen what might be possible? For example, if the reeds are .4mm was that thickness decided upon because of performance or commercial longevity. Perhaps a .3mm reed gave better performance, but tended to 'fret' after a short time and needed periodic replacement. Maybe wider reeds can be installed with a bit of porting work to the block and the jug. Those reeds are rather narrow and a wider reed would give the same flow with less resistance.
One of the things I didn't like about the 370 Suzuki reed/port system was that the reeds were in the intake port. As soon as the piston started opening the intake port, the pressure differential on the reeds would start dropping. The reeds would then become less efficient at the very time that demand in the crankcase was highest. The 6100 system, by having separate intakes, doesn't have that problem. The 6100 keeps the reeds open and flowing as the piston hits maximum piston speed.
From the few pictures I've seen of the jug, it looks like a rear boost port could be ported into the cylinder. Start with a narrow port of 70 degrees, about 1mm below the side transfer openings and see how it works. Try a bit wider, maybe go to 60 degrees - perhaps the loop-scavenging can be significantly improved over the 4-port. That could be very important if the intake system was modded to improve the flow.
