Mastermind Meets The MS660
Chief Cat Herder
3:45 AM
I have two different wheels I use. One is mounted on a 3/8", and the other is a 1/2" drill chuck. Just what I had handy.
Mike......AKA Homelite410 made me these aluminum discs. They are 7" in diameter. I just print off these degree wheels and glue em on.
Chief Cat Herder
3:45 AM
Now, this part is tricky to explain. To make sure you get your advance, use a rope in the jug as a piston stop, then hold the flywheel tightly counter-clockwise against that stop. While holding it, snug the flywheel nut up.
