Here I'm popping the wire off using the blade of a screwdriver rather than pulling it off. Many times, the spade connector can be damaged by pulling it off.
I use a double ended, threaded flywheel puller on most Stihl saws. It's just a cheap Moped tool from ebay.
The MS461 is rev limited to 13,500. To make the saw unlimited I use either a 460, or 660 coil. On this saw, I have a 660 coil to use.
As you can see in this pic, all three holes don't line up using the 660 coil. On the 460 coil there are only two bolts as well, so I don't worry about this.
Let me back up just for a second. Here's a shot of the flywheel key.
See how the area I cut is on the right side? That will make the flywheel rotate counter-clockwise further than it was from the factory. I've found that by taking .020 from the key that I get around 6° advance.
Now here I'm holding the flywheel against the rope I'm using as a stop, then I tighten the flywheel nut as tight as I can while holding it like this.
After it's snugged up to hold the flywheel in place, I rotate the engine to catch the stop in a way that allows me to finish tightening the flywheel.
Getting ready to check squish. I've got a few rolls of .030" soft solder that I picked up on ebay awhile back, that's why I twist this stuff up like this. That and it's real handy to be able to make it any size I need. I should point out here that if your solder is too large it will give you a false reading.....
This bolt holds that flange/stuffer hicky, and it is higher than the case where the jug bolts down. If you try to delete the base gasket on the 461, you must grind the head of these two bolts down about .020".
We now have .065" squish clearance. We'll want to take .040" off the base to end up at .025.
