- 11:02 AM
- Dec 3, 2015
- Banner Springs Tennessee
Oh no that's what Elvis did.Starting on the uppers.
If you toast a piston. ..it's $80 for oem....which you are stuck with.
I'm just not sure the extra gain is worth that annoyance to me.
Wow lots of grinding on those. Is it my eyes or do you leave one of the lower transfer ports untouched? If so why is that?
If you don't lend out your saw, you significantly cut down on the chances of straight gassing your saw, which is the #1 reason I've seen for toasting a piston.
Man I was wondering if you had the mains opening first. I could have sworn so in the photos.
...but isn't it more usual to have the secondary open first?
ok, serious question... on the lowers, since you are significantly increase the size of the main lower by grinding that stump back, when you grind on the divider, why not grind the divider in favor of increasing the size towards the 2ndary lower?
If then though you want velocity on the secondary, wouldn't keeping the 2ndary as narrow as possible at upper be the objective? ... and wide at the lower so as to cram as much air/fuel as quickly as possible.... like a bottle neck?
