- 2:26 AM
- May 30, 2016
- Ct
PHO 750$ shipped. What’s used: saw was built on used 394 cases and tank handle, excellent condition 394 crankshaft and flywheel. What’s new: I had randy rebuild the bottom end with new OEM bearings, seals and case gasket, new OEM P/C kit that Randy ported, new OEM decomp valve, new OEM 395 carb base and intake tract/carb (not cheap!), OEM fuel/impulse line, new outer bucking spike, new aftermarket muffler that is gutted and has dual ports, Screens intact. That is the only aftermarket part on the whole saw. Screw threads that were repaired... lower inner bucking spike screw is tapped to 6mm and solid. One pull start cover screw is tapped to 6mm. Two av limiter pin screw holes are helicoiled. All are solid repairs. What’s damaged: the starter cover has two semi broken fins. This doesn’t affect functionality and is only cosmetic. The saw is ready to work and I’m selling because I have other priorities and need to free up funds.
