M-tronic Auto tune chainsaws
Bjorn
12:42 AM
Sweden
I have a question. How would an electric carburator respond if you put on a pipe, expensioncamber to the engine? Best Regards Bjorn
TreeLife
I'm Dominick
3:42 AM
Berkshire County, Massachusetts
I have wondered the same thing myself. If the porting and pipe was geared to work right around the limiter if it would be nutty or slow or what.
Bjorn
12:42 AM
Sweden
http://www.dragonfly75.com/motorbike/ECtheory.html
I found this on the net very interested reading.
Bjorn
12:42 AM
Sweden
I ask redbull but hi had no anser, how it would react or work. Mabee som other can try this and se how it works
Bjorn
12:42 AM
Sweden
When you do a simple Muffler mod the carburator Will correct the fuel curv. so I think it would do the same With a pipe. But a pipe is alot of work to make and calculation so i want to be sure before I build one.
Lightning Performance
3:42 AM
East of Philly
Just get someone to swap a pipe from a 66 to a 661. That should give you some feedback.
RI Chevy
3:42 AM
earth
Good question here.
angelo c
Coal Member
3:42 AM
So I forgot my ingineering hat back in the truck but.....its still a carb and limited by a jet and the amount of air that passes over the sensor.... so it will allow "some" more flow due to better scavenging but it will be within a range the Germans ungineered in the first place. So at best a little more powah and a much better sound. Did the pipe help the chain sharpener do its thing better ?
(Sarcasm inducted)
