- 1:12 PM
- Dec 23, 2017
- Hatley, Wisconsin
Last week, 2 of the saws brought to me to repair have really challenged me. First one is a 357xp with the oem fubar carb. I couldn't get the saw to idle. Ordered a new carb. I couldn't get that one to rev. Carb #3 should be here later this week.
Saw #2, 038av. This one starts and idles great but will not rev. I rebuilt the Tilly HK carb twice. The valve jet is clear and works like a check valve. I believe that is correct. Impulse line is clear and in good shape, intake boot is good, fuel line and filter in good shape. Pull the trigger and you can hear when the throttle plate opens, but the rpms don't go up. If I raise the needle lever a touch, then it floods. I try adjusting the high needle richer and it smokes more. Lean it out and it will stall while trying to rev it.
Am I missing something here?
