Box of 70cc goodness. For $45
With cylinder scored of course. Think it will clean up.
10 minutes of work. Needs a little to go.
Used these to get it there
Where did you get those scotchbrite mandrels? they must work great for removing transfer.
I saw that
Did u get an air filter with it?
Thanks!!!!!Got them here, they have a shop at the outlet mall. Boxes of various shapes and sizes. The store is cross between harbor freight, northern tool, and good Ace. https://www.workshoptools.com
Is there a K&N substitute like for the 288?Yeah i saw the elbow there, gettin real hard to find those filters.
Ha! That’s the way to do it! Strike when the iron is hot...twice!That i dont know, never looked into it. I have 2 hd filters, as much as i iuse my 272, im set for life
If the AV’s are like the ones on a 288 you don’t need a wrench for them. A pair of needle nose pliers work well for removal. I use the mount screw to install them by threading it in til it bottoms out in the threads. Never had problem replacing them in this way.Easiest cylinder clean up I ever done. Those buffs worked well, but the scoring wasn't real bad. Going to finish tearing it down to bare bones. The way I got it was in a box already apart. Starting to compile my shopping list, OEM gasket set, seals, oil pump oring, and a meteor piston for now. Going to order some of the AV wrenches as well.
