Evansaw
- 10:48 PM
- Nov 20, 2017
- Greece
We had impulse line issues with the 440 kits, but not the 660 kits. The impulse barb was slightly longer than stock and would intermittently bottom out against the side wall if the impulse line. Drove us nuts, cause all the lines were OK.
Same symptoms as above. Ran fine but wouldn’t start because the pump side of the carb wasn’t getting proper signal.
I bet it’s impulse or carb. I’d swap the impulse line or at least inspect it first.
Thanks for your input Al. I was waiting and I received from members like you their experiences and targeted to the problem answers.
