Log Splitter Size Needed
5:30 AM
cycle times are calculated by the pump and cylinder sizes i have ran a few different brands for a cheaper priced one the dirty hands brand from tractor supply does good the one i ran was a 4 inch cylinder and 13gpm pump good cycle time and power
i built one a few years ago i used a 5 inch cylinder and 16gpm pump and it has about a 18 second cycle time i may change it to a 22gpm to gain more speed but with the bigger cylinder i can split anything i put through it if it cant split it it will cut through it
5:30 AM
So I grabbed this one.
It did what I needed it to do. Split mostly big rounds and got less than I thought out of a days work with 2 buddy's. Likely only 2 cords, so I've gotta get some more done and stacked so it's dry by November.
5:30 AM
Two negative points about this splitter:
First, the wedge rides in a channel that's very sloppy. There's no consumable guide that's replaceable. The other I has used rode on a rail with two copper (now teflon) sandwiching the rail. This one forces pressure along the back of the beam, which I greased. Will likely take a lifetime to wear out.
Secondly, and the most annoying, is a welded on "+" pattern on the base where the log sits.20170709_143135.jpg
I realize why it's there, but it made it impossible to slide big rounds over the plate without lifting them. 36" x 20" red oak rounds were likely in the 200#+ range and my back is still screaming at me.
Pretty sure the Hypertherm is coming out and I'm gouging these puppies off.
5:30 AM
The log holders are homemade from old chainlink fence post, are 4' high/4' wide and space around 20 ft apart in the photo.
The logs are 18-20' long.
RI Chevy
5:30 AM
earth
Looks good Al.
All those splitters are like that so the round don't slip off when the pressure is applied.
hseII
AKA - Karenberly's Husband
5:30 AM
West Georgia
Secondly, and the most annoying, is a welded on "+" pattern on the base where the log sits.View attachment 77711
Build some sort of bolt on guide out of some of hard plastic.
kingOFgEEEks
5:30 AM
Tioga County, PA
That's not a small pile of wood for a day's work. I agree it could be bigger, but in my experience, working with big rounds like that really slows things down.
I have the Brave 20T dual split (the not a knock-off version, similar to what @P.M.P. has), which is horizontal only. However, my strategy is to noodle everything I don't want to lift. It actually ends up being faster that way, and I can split a full cord in 1-1/2 to 2 hours, depending on the type of wood, by myself. (pre-bucked, 18-20" long, in a stacked windrow, thrown into a pickup truck or pile)
I have heard good things about the DHT units. My one humble suggestion would be to degrease the beam/wedge interface, and use a dry lubricant. I keep my beam lubricated with a WD-40 brand dry lube, and it still has paint on it after about 8 or 9 cords of use. Grease attracts dirt and debris, and could potentially increase the wear rate on your splitter beam.
Chainsaw Addict
GO HOOSIERS
5:30 AM
Indianapolis
I'm sure 22 or 27 ton would be fine. I only have a 35 T only because bargain near new used.
Sent from my SM-N900P using Tapatalk
