Brewz
- 1:52 AM
- Jan 16, 2016
- Hunter Valley - Australia
I have little to no experience with 192s. Why would it have less compression?The 'T' (not TC) version has higher compression so it should run well if everything else is good.
I have a 14" .050 light bar on my 192t. It pulls that setup good with a muffler mod, and advanced timing. Not near as strong as a ported 200 but it's still good enough.Mine is a TC and it rips pretty good with .020 advance, muffler mod and limiters trimmed. It felt better/stronger than the 338xpt I had at the same and ended up selling to a buddy since I liked the Stihl better.
Granted, I've never run a 201t or 200t and it's running a 12" bar.
Does it melt bits out of the chain cover with that slot in the deflector?View attachment 53326 View attachment 53327
Brewz- I open up the muffler outlet as well as modify the deflector on these and it makes a difference. Also trim off the carb limiters.
The TC (ergo start/ez start) version has a pre-exhaust groove in the cylinder, but the older T cylinder does not. Compression on a TC is usually around 125, and on a T I've seen it at 160-170. Piston is the same, and cylinders are interchangeable.
I wonder if the groove effects running compression at all???
Copy thatBrewz- some other things to check besides the muffler screws: Check the ignition screws- they come loose quite often and then well.... Also check the 4 screws holding the engine into the plastic case. When they come loose it will break a mounting ear off the cylinder.
Seems to me that it would. It's letting gasses escape past the piston after the exhaust port is closed off.
